LT1/LT4 Tech 1993-1997
rockers a little loose
Old 01-17-2019, 01:50 AM
sewerrat's Avatar
Default rockers a little loose
replacing my v/c gaskets. haven't started my vehicle for several weeks prior to removing the valve covers. after removal I decided to wobble the rocker arms. I noticed a little play on all the rocker arms that are on base circle. is this normal or should I re-adjust the preload? I know the lifters will pump up after start up but was just wondering if any harm resetting the preload at this time. vehicle has 140k and has a faint valve tap but engine runs fine. tnx
Old 01-17-2019, 06:21 AM
should be fine. they will move around a bit while not running. not ticking or making any funny noises are they?
Old 01-17-2019, 04:47 PM
sewerrat's Avatar
Slight tapping when doing a gradual accel. No tap on hard accel or decel engine runs fine. Just a note, removing the pass side kind a kicked my ***. Alt, Air inj pipe and trans dipstick needed to be removed. Was there an easier way?
Old 01-17-2019, 09:00 PM
My LT1 always had a little lifter noise, it was a high mile motor but ran great and was as you describe so I'd say it's normal.
Old 01-18-2019, 03:45 AM
i didnt have to remoe the trans fill tube
I Shine
12-18-2013 06:12 PM
fronzizzle
82-92 V8 Tech
05-06-2013 06:02 PM
Pro78z28
09-03-2011 03:11 AM
bellsz28
02-15-2011 09:55 PM
DarlingReject
10-04-2010 11:31 PM
Quick Reply: rockers a little loose
