Replacing Radiator oulet tank?
Can you replace the radiator outlet tank? I found the part for $50 and my side tank is leaking because of a small crack. Has anyone does this before? A new radiator with a built in auto trans cooler is like 500 bucks(way to much).
if u are talking about the overflow yes u can replace it. if u are talking about the heat transfer for the trans then i dont think u can. well u probly can if u have access to a radiator shop. i think the dang things are made of plastic. what yr and model car?
500 bucks? Where are you shopping? Rockauto has aftermarket radiators for $112 and AC Delco ones for $237. I picked 1995 out of the air, not knowing what you have. http://www.rockauto.com/catalog/raframecatalog.php
