LT1/LT4 Tech 1993-1997
removing shift kit
Old Jan 19, 2007 | 06:04 AM
kyleb's Avatar
Default removing shift kit
hey everyone i have a shift kit on my z and i want it off!
i need to sell my car and the shift kit seems to make everyone think that my tranny is messed up cause it shifts so hard. when you drive easy you get like a tiny wiplash in a way (you feel a tug)and accerating quickly itslams hard and it makes loud noise( think its the console making the noise but still)
this does sound like a shift kit right?!?!?!
anyways how do i take it off? i dont even no where it is? is it programmed meybe?!
thanks, its hard to sell if it has it people assume theres somthing wrong!!
Old Jan 19, 2007 | 12:17 PM
Default RE: removing shift kit
First you should check for bad transmission & torque arm mounts. Then you ned to undo whatever you did to put the kit in, each brand is a little different.
Old Jan 19, 2007 | 04:30 PM
kyleb's Avatar
how should i check it? what is the best way how do i tell?
Old Jan 21, 2007 | 02:33 AM
kyleb's Avatar
okay i checked the tranny mount(is this the same thing)with a pry bar and it dosent move or anything and it deffinatly dont look cracked. (chilton says this is how to check it) so could it be that its just the way it is and meybe i need to bolt down the console better meybe?!? lol
Old Mar 16, 2007 | 06:15 AM
INTENSE_Z's Avatar
most trany kits ive done u need to drill the plate in the valvebody so u may need to find one at a local dealer might have one that u can order or check with a trans shop but it may be better to take some money off the selling price than that or u cold have the buyer get in the carand explain that when hold ur foot on the brake with it in gear andin u can get the car to move or turn the tires with no trans noise like popin or grinden and no big fluctuation in rpm then theres nothing wrong with the tranny thats how a dealership will test a trans and the same way at the speedshop u might try that or have them take it to ashop they will do the same thing i just said
Old Mar 17, 2007 | 09:07 PM
kyleb's Avatar
thanks intense i didnt know that . good sht. well im not selling it now its to sweet and i wouldnt want to see somone driving my car around town! lol yea tho there is no noise when i hold the brake and move the wheel
Old Mar 17, 2007 | 09:39 PM
coprunr's Avatar
not move the wheel , come to a complete stop , put the car in drive , hold the brake and snap the accelerator open, and close , real quick. if you heard a loud bang from the console area, the trans mount is broke. it's a common problem with stock sty;e mounts because of the torque arm.
Old Mar 18, 2007 | 02:31 AM
kyleb's Avatar
okay, so if it is broke is it hard to fix??!?!
ill try that so do i keep the brake on when i hit the gas real quick or do itake my footoff the brake?
apetsel
Mar 25, 2011 06:27 PM
bigtim1985
Sep 29, 2010 11:28 PM
th3po1son
Jan 20, 2008 08:56 PM
94Z28SHAKER
Jul 11, 2005 02:38 AM
