LT1/LT4 Tech 1993-1997
rear end 3.23 gears ? 97 ss
Old Jun 18, 2009 | 08:36 PM
stiletto's Avatar
Default rear end 3.23 gears ? 97 ss
hi guys well the summer is back and camaro back on road got my rear transfred by mr muffler m59 in michigan they forgot to add spicifis additive my clutch plates are making noice . if ruined going to 3.73 auto trans lt1. i wonder though if it is a true gu5 according to car plaque at 55 mph is reads 2k excactly in overdrive anyone else with a 3.23 know what there rpm;s are? i wonder if it might be3.23 or is there a way to find out with phsically taking cover off it hauls you know what fast car repair said 13,4 percent hp gain if going from 3.23 to 3.73 al sound correct sorry for the mixed up message haven't been here for a year but trying to eat mustangs even the super ones thankls Stiletto
Old Jun 19, 2009 | 08:27 AM
whammer3024's Avatar
ROTM Winner
you won't gain any hp whatsoever by switching the gears...
Old Jun 19, 2009 | 07:41 PM
stiletto's Avatar
ok then but with bigger gears wont auto trans ss get a qwkicker take off heard aomeone years ago 400 hp camaro with 4.11 gears would top out at 90, mph but get there i a heartbeat thanks Richard though I am starting to think 97 sale to 69 camaro thanks cux my camaro probably not enough for a down payment on a nice 69 and besides only 21,700 on od for a 12 years old chevy not too shaby
Old Jun 25, 2009 | 12:42 AM
u will gain tourque at the rear wheels. to check the gear ratio (block the front tires and use something to support the car just in case) u can jack up the rear wheels, turn the tire one time around and count the revolutions the drive shaft turns. watch the other rear tire if it turns the same direction this will work if it turn the oposite direction u do not have a posi rear and it will take two people to do, one to turn each wheel in the same direction. if the shaft turns 3 and 1/4 turns u have a 323, if it turns about 3 and 1/2 turns its a 342.
Old Jun 25, 2009 | 08:14 PM
stiletto's Avatar
hi crabby thats exactly want i wanted to know i vote you as president of this site Thanks Stiletto
Old Jun 26, 2009 | 03:48 PM
97SScamaro's Avatar
I have a 97 SS with 3.42 in the rear. Pretty sure thats what they all have but im not sure
Old Jun 26, 2009 | 11:47 PM
stiletto's Avatar
hi 97ss well i am gpoing to try craby's idea it seems my camaro loves the 2k rpm even when babiein it. auto trans all my other cars lower the rpm when they hit overdrive 54 mph but maybe camaro wants more speed don;t know where it shifts to overdrive. do sound pretty mean when i open her up a lil totl system with 3 inch intermeadite pipe and dual hiflow cats thinkin of having air inlet bored out it's only 48 mm while our brothers LS1 have 90 mm stock thanks to all this site rules!!! Stiletto
Old Jun 27, 2009 | 08:23 AM
Margarita Girl's Avatar
Torque gets you out of the hole faster but too much gear means you will run out of top end sooner.
My car is NA and I switched my 3.55 stock gears for 4.10's. Awesomeness!
Also if you are using larger rear tires to gain traction, the increased circumference reduces the gear effect.
Another reason you see drag cars with balloon tires running crazy gear numbers.
Old Jun 27, 2009 | 08:53 AM
blackz87's Avatar
SLP cars had two ratios:
3:23 limited slip Auto
3:42 Limited slip 6-sp
That was it.
Old Jun 27, 2009 | 09:07 AM
Back to your first question. Just put the limited slip additive in and run figure-8's in a parking lot to work it in. You'll probably have to siphon off some oil to make room, unless they didn't have it up to full. Clutch style limited slips need the additive to keep the clutches from sticking together when you make a turn. Without an additive, you get your chatter. It's highly unlikely that you did any prolonged damage. If the chatter goes away after the additive, as it should, then you're fine.
