LT1/LT4 Tech 1993-1997
Rear disc brakes, 1995 Z28
Old Oct 24, 2011 | 10:57 AM
cantdrive55's Avatar
Default Rear disc brakes, 1995 Z28
Has anyone changed rear pads on the Z28? The emergency brake mechanism is getting in the way. The top bolt on the caliper is easy to loosen, but there's a hex key on the bottom that's near impossible to get a hex key wrench on. Is there a different way to get the e-brake mechanism out of the way so I can get the caliper off?
Old Oct 24, 2011 | 11:51 AM
i used a socket set i have with hex heads. dont recall any issues
Old May 18, 2020 | 06:29 PM
Joe Siroski's Avatar
Hello,
im in exacty the same situation u talked about with the e brake in the way. What did u end up doing?
Old May 19, 2020 | 10:02 AM
Default E brake
It was a while ago when I did this. What I recall is taking the entire ebrake assembly off of the disc rotor. There is some kind of hardware holding it on. Look for any screws or bolts holding it on. If that does not help. I would suggest searching on youtube so you can have a visual aide.
LittleBill
Apr 26, 2012 12:36 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
microkid
Jul 23, 2007 10:09 AM
mcnair
Apr 30, 2007 06:42 PM
sewerrat
Dec 8, 2005 02:24 AM
