LT1/LT4 Tech 1993-1997
rear brake squeal?
Old Mar 13, 2010 | 06:50 PM
1bad94z28's Avatar
Default rear brake squeal?
i just replaced the rear brake pads on my 94 camaro. took it around the block it the back brakes are making a loud squealing noise. it stops when i hit the brake. its very annoying and when i turn left sometimes it will get real loud for a second and then go back to the normal squealing. anyone have any ideas on what it could be or how i could stop it?
Old Mar 13, 2010 | 07:55 PM
Turbolag86's Avatar
did u double check to make sure the bolt on the caliper is tight and the caliper is seated firmly on the rotor ? My friend and I just replaced the rear pads on mine also. Maybe its because the pads are new ? how do ur rotors look? Are they worn ?
Those are just ideas for you to ponder on, if they don't fix it maybe they will spark an idea for you.
good luck....let me know what the noise is !
Old Mar 13, 2010 | 08:14 PM
1bad94z28's Avatar
i will look into that tommorrow. i didnt replace the rotors and they are a little worn but not too bad.
Old Mar 14, 2010 | 08:04 AM
squeel should be a metal on metal issue. look for any signs of wear that would be metal on metal.
Old Mar 14, 2010 | 10:24 AM
Turbolag86's Avatar
Before replacing the rear brake pads and the rear driver side rotor, my car also would make the squealing when turning.
Old Mar 14, 2010 | 02:18 PM
midrange's Avatar
do you use shims when putting pads on the back? Shims help with noises and squeeks. etc.
Old Mar 14, 2010 | 03:28 PM
Turbolag86's Avatar
YES ! make sure the shims go on with the pads !
Old Mar 29, 2010 | 06:14 PM
djrewind's Avatar
Default djrewind
getting ready to replace rear brakes on my 2000 conv., anything special
to watch out for?
aleggio
Apr 19, 2012 04:29 AM
65eglide
Mar 25, 2011 09:05 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
Failed Devices
Sep 7, 2010 09:27 PM
calvert
Jul 5, 2007 07:32 PM
