Random Misfire
#22
Garage tested it, said it was thew #7 cylynder, of course. I changed the plug and wire, only had a few hundred miles on the others, seems to be fine now. Seems like I dodged a bullet this time. Thanks fellas.
Hopefully, this was the only issue. I'll send the injectors in this winter after I park it.
This place rocks. I'll certainly be back. Maybe I can be of some help to others.
#23
before you go off spending hundreds of dollars on injectors, do what camaro69 said first. Find out which injector(s) are missing/clogged and soak them in carb cleaner. Cheap and effective. Saves hundreds of dollars on your end, only spending around maybe 3-5 for the carb cleaner..
