LT1/LT4 Tech 1993-1997
Procharger
Old Apr 1, 2008 | 04:44 PM
95z281LE's Avatar
Default Procharger
I was talking with my engine builder the other day about getting somemore power (buddy just got a 600rwhp 04 cobra and i dont want to lose to a ford) and he said that I should Build and stroke the bottom end to a 383 and get a procharger.He said that i should be able to get 650rwhp out of that. does that sound right to any of you?
Old Apr 1, 2008 | 07:28 PM
robmnrd's Avatar
Default RE: Procharger
I don't know a lot about forced induction, but that seems a little bit high. I would be more than willing to have someone say to the contrary though.
Old Apr 1, 2008 | 08:09 PM
95z281LE's Avatar
I thought it was a little high as well.I looked on Prochargers website and they claim that the D-1SC gains 75% more power then stock. My current setup makes 385rwhp and I did a little math and that came out to 672rwhp!
Old Apr 1, 2008 | 08:27 PM
robmnrd's Avatar
Good call.
That supposed '75%' is crank, too. take away 15% drivetrain loss, and you're at about 571whp. A bit off of the 650 mark.
Throw a little nitrous in to the mix, and you've got 650+
Old Apr 1, 2008 | 09:18 PM
SpecterGT260's Avatar
Ninja Administrator
its all dependent on boost.
if you forge the bottom end and drop compression to about 8.5 you can easy hit that. possibly with a D1SC which is a bigger unit, similar to a Strim. the issue is making your motor capable of handling the boost. do you currently have a 383? building a 383 with heads/cam to match will make you well over 400rwhp. adding a SC to this can get you 650 in a heartbeat, just expect to pay for it. it will be more than $20 [&o]
Old Apr 1, 2008 | 09:35 PM
95z281LE's Avatar
thank you for the info and i can assure you money is not a factor when it comes to the car. I plan to keep building the car as soon as i get bored with the current setup
Old Apr 1, 2008 | 09:39 PM
Ninja Administrator
just be clear with your builder you are going FI from the beginning. this means forged bottom, low compression, blower cam, and big port job on the heads. a D1SC can push 20psi pretty easily and this will definitly get you where you want on a 383
Old Apr 2, 2008 | 03:34 PM
95z281LE's Avatar
I was thinking like 18psi with 9 to1 compression with methanol inj. I was also planing on having my heads hand ported (I have AFR heads) so i shouldnt need more CNC work done.
Old Apr 2, 2008 | 03:42 PM
robmnrd's Avatar
I thought you were just talking about buying a crate 383 and throwing a SC on it. With the type of stuff you guys are talking, 650 definitely isn't out of the question.
Old Apr 2, 2008 | 10:59 PM
95z281LE's Avatar
All my friends think I'm crazy and ask me why I didnt buy a crate motor. That would be cheating I think to use anyother motor in a car that came with an LT1 is a crime and those who do it should be punished. Anywho do you boys know of a bullit proof crank for the LT1?
gravensg
Dec 12, 2011 08:30 PM
Phalen123
Jul 12, 2010 12:46 PM
noer
Oct 15, 2009 08:34 AM
noer
Jul 26, 2009 02:56 PM
