pro charger?
I have a 96 z with the lt1 its 30 over with a rv cam it also has a vortech pro charger as far as I can tell it has the stock throttle body I wanting to upgrade a few thing I was wanting some suggestion of what might have worked for you injectors, tb, cam, im fittin on doing a bunch this some i'm buying now any input helps thanks vile_verlin
If the Procharger was installed as a kit all the stuff you are worrying about has been taken care of. Of course, if you are going to change things around, you will need a plan. Mainly, how much power you want, and how much boost you want to use in getting it. To get power using high boost is tough on the engine and requires more fuel than if you got the same power using less boost and better breathing.
