LT1/LT4 Tech 1993-1997
power set up gotta know what i should do
Old Oct 1, 2011 | 06:56 PM
SS/Z28cam's Avatar
Default power set up gotta know what i should do
Ok have a 94 z28 convertible with a bone stock lt1 I have installed long tube headers deleted the egr system also installed a y pipe and a gmmg exhaust setup. Transmission is a 4l60e with 2500 stall and Corvette electrical internals, clevit green racing clutches, b & m trick shift kit that has been modified to keep the shifting stiffer and micro polished steel valve body to hold the pressure. In the rear have 2 set ups a posi 3:42 gears and a 4:10 set up I can switch them out in 20 mins need a good idea for a, cam without programming my pcm to much already porting intake and heads. So any good ideas for a cam set up I should do is welcomed.
Old Oct 2, 2011 | 12:56 PM
who is porting the heads and intake. if elliotts i would go with what he recomends for what you want.
Old Oct 2, 2011 | 01:30 PM
SS/Z28cam's Avatar
I'm port matching them my self
Old Oct 2, 2011 | 09:17 PM
give a call to elliotts and tell him what you have and want then order up a custom grind of his.
Cactus
Jul 19, 2010 08:54 PM
EastonBall
Oct 29, 2007 07:38 PM
