LT1/LT4 Tech 1993-1997
popping noise when shifting
Old Jul 2, 2006 | 06:20 PM
NomadicZ28's Avatar
Default popping noise when shifting
Alright guys I need some input here so tell me what you think...the other night when I was pulling onto the highway I was shifting just fine got all the way to 4th gear and it got stuck...it would come out of 4th into neutral but thats it, i finally had to force it through all of the gears, then abotu a week after that when I shifted to 3rd it made a loud popping noise and my ABS INOP light came on and then went off when i turned the vehicle off. anyone havve any clue what could be wrong? thanks guys!
Old Jul 3, 2006 | 12:18 AM
Default RE: popping noise when shifting
Do you know which part of the car made the noise? Is the car still driveable?
Old Jul 3, 2006 | 06:36 AM
NomadicZ28's Avatar
The noise is coming from the tranny/ clutch area, the throw out bearing is going out on it so I figure the clutch is too(maybe) the car is driveable it only does it when I shift faster than usual and when the car is at higher rpm's. it doesnt do it when Im cruising just when I shift hard and fast
Old Jul 3, 2006 | 08:43 PM
I think you are on the right track. The throw out bearing is probably worn and not turning freely and grabbing on the pressure plate fingers & making a mess.
Old Jul 4, 2006 | 05:15 AM
NomadicZ28's Avatar
Alright cool, thanks for your info!
Davila2000maroRS
May 1, 2012 09:40 PM
Davila2000maroRS
Mar 14, 2012 06:59 PM
akbyrner92
May 15, 2008 05:03 PM
Captain205
Apr 25, 2008 12:15 PM
