LT1/LT4 Tech 1993-1997
pleas help p1380,p0300
Old Oct 11, 2011 | 11:45 PM
lilLT1's Avatar
Angry pleas help p1380,p0300
ok i brougt a autozone distributor and put it on then coolent leaked on it i dont no if that made it worst but it drove no different fom original distributor so it had me guessing the a friend off mine just swaped for ls1 so he gave me his oem distributor and it drives way better but still have same miss fire code p0300 and also p1380 it dives good cold but when warm it start missing harder i have duralast wires from auto zone and ac-delco rapid fire plugs so do anyone have ideas on p1380
Old Oct 12, 2011 | 08:11 AM
Psycho's Avatar
A new distributor will not be affected by some coolant leaking on it. The seals are new and should prevent coolant from leaking in.
LS engines use a completely different ignition system.
Does your check engine light come on? What you are describing is when your engine gets warm, what you probably are experiencing is the engine going into closed loop operation. It is running poorly when in closed loop.
You probably have a poor connection in your wiring causing the "rough road data" problem. The sensor(s) are getting an intermittent signal.
I cleaned all my connections with electronics cleaner and then smeared dielectric grease into the connection before I plugged them back in.
Old Oct 12, 2011 | 11:41 AM
lilLT1's Avatar
Thanks i no i sound slow what Wires should i clean and give me the steps u would do to fix the problem or do u no someone in. D,c m.d v.a please its killing me
lilLT1
Oct 12, 2011 07:28 PM
lilLT1
Sep 23, 2011 12:26 PM
Jonlajoie
Sep 4, 2011 09:31 AM
hotrodder83
Apr 1, 2008 01:01 PM
blk79camaroproj
Nov 16, 2005 12:36 PM
