Path to 400?
Most cams and long tubes aren't going to pass emissions. Unfortunately, those 2 pieces are big performers. You could always look into a smog waiver, but I can't imagine it being cheap in CA (if it exists).
yea i might get a legal cam and see about headers. i kinda wanted lt headers because of their performance.... i do have a good friend... who can get one of his good friends to pass smog for 250-300. worth it?
Edit: Just curious, how much will cams and the LE2 heads add (hp/torque-wise)?
its going to be tough and expensive to get to 400 in cali. you have to have the cats in the same place as original and im not sure you can use high flow cats. you better do some research on it. im sure theres lots of info on the net for ya.
I might be wrong, but when using the 224/230 cam an upgraded stall/converter isn't necessary you can still keep it stock? Granted it wouldn't be the most optimum choice but still would work correct? Even then 226/232 says nothing about changing these on an Fbody, only the Bbody would need a stall upgrade and gears....?
