LT1/LT4 Tech 1993-1997
Path to 400?
Old 09-29-2011, 12:24 AM
ls1_lyh's Avatar
Default Path to 400?
2 Questions:
How much hp/torque will a LT1 make with intake/header/exhaust/throttle body?
How would i go about achieving 400hp at the wheels without FI with a LT1? Looking mainly at the above mods plus maybe cams? and a tune after? What is required to reach 400? or at least a number close to 400 at the wheels?
Old 09-29-2011, 12:43 AM
Catmaigne's Avatar
Assuming the headers are long tubes and there are no cats, you should expect 290 out of a manual car. Subtract 15-20 for the auto. Forget about the throttle body, it doesn't become a bottleneck until you're pushing 425-450 at the wheels.
400 would be intake, exhaust, long tubes, cam kit (cam, rockers, etc.), ported heads and intake, and a good tune.
http://elliottsportworks.com/home/?page_id=53 Everyone raves about the LE2 package.
Old 09-29-2011, 01:28 AM
ls1_lyh's Avatar
LT1 LE2 « Everyone raves about the LE2 package.
so about the LT1 LE2 heads... it says that itll produce 370-380 whp. im going to assume this is with full bolt ons + tuned. And there is also an option with custom cams (410+hp?). does this mean i dont need other cams? or still need stuff that would come in a cam kit like valves, roller rockers, etc? sorry ahead of time for the n00b-iness
Old 09-29-2011, 02:07 AM
JGuy07's Avatar
The LE2 package comes with valves, springs, locks and retainers all assembled and ready. Get one of the custom cams with it, I plan on going this route when I can. LE2 package with the 224/230 cam most likely. With crane gold 1.6rr and crane rods....I think ha
Old 09-29-2011, 09:14 AM
check my build, i am close to 400.
Old 09-29-2011, 02:36 PM
JGuy07's Avatar
I might be wrong, but when using the 224/230 cam an upgraded stall/converter isn't necessary you can still keep it stock? Granted it wouldn't be the most optimum choice but still would work correct? Even then 226/232 says nothing about changing these on an Fbody, only the Bbody would need a stall upgrade and gears....?
Old 09-29-2011, 03:01 PM
right i used the stock trans and converter for a short time. it was kinda a pain, idle wont hold at 800, goes to 1000 most times and with the setup i have now it will sometimes go to 12. once in gear with the stock trans it would idle down and want to go.
Old 09-29-2011, 03:29 PM
JGuy07's Avatar
Is it a steady loping though? I haven't looked much into internals and stuff yet since that is far away for me. I know an obvious tune is needed afterwards, but some seem to say different things on how the cam effects the idle and rpm ranges.
Old 09-29-2011, 06:01 PM
ls1_lyh's Avatar
thanks for the info and craby ill check up on your build thread. any idea of price for engine mods only? i researched and i came up with ~2.5-3k. i could be completely off though
Old 09-29-2011, 06:25 PM
ls1_lyh's Avatar
oh and i forgot to ask this, but this will be my project car. which has to pass inspection/smog to be driven on the street. any of these mods make the car fail CA smog? headers, intake, cam, heads?
Quick Reply: Path to 400?
