LT1/LT4 Tech 1993-1997
painting vehicle surfaces
Old Mar 28, 2010 | 10:10 PM
imcdowel's Avatar
so it would be sand and bondo if necessary than primer, sand, paint, sand, paint sand. clear coat, sand then polish? should it be wet sanding you think?
Old Mar 28, 2010 | 10:15 PM
CraZ28's Avatar
Banned
Primer! What? That's too thick. Think thin.......... Just keep the good paint you have already. Maybe a light coat of primer on the bondo. The paint will stick to anything as long as it's sanded and clean. Just "think" sand/clean/paint, sand/clean/paint, and sand before you clear to "dull" it. Then the clear "pops" it!!!!!
Old Mar 28, 2010 | 10:21 PM
CraZ28's Avatar
Banned
The "wet" sanding is done last after you've lightly sanded the clear. It's done with a compound and sponge pad on a electric buffer.......Actually your sanding it with the alcohol soaked cloth patch but your still keeping it dull...Go for it!
Old Mar 28, 2010 | 10:25 PM
imcdowel's Avatar
ok thiiiin ill take that to the max then like you said. if it goes wrong i can just try again. actually you can see what the awfulness looks like in an album titled damages in my profile. it just shows the front bumper its much worse up close. you inspire confidence in me!! might be a bad thing but eh...
Old Mar 28, 2010 | 10:28 PM
imcdowel's Avatar
ill use some of this method but much thinner as you say. http://www.smokedtaillightstint.com/ this is for tinting tail lights but same concept.
Old Mar 28, 2010 | 10:29 PM
CraZ28's Avatar
Banned
Might as well paint the whole car and be done with it. Just scuff the rest of the good paint ,do a little body work, then put a design or something on the hood, sides! Don't be scared!
Old Mar 28, 2010 | 10:31 PM
CraZ28's Avatar
Banned
You keep it thin if you sand/clean/paint! The painters are not going to tell you their secrets! I am just trying to help a fellow camaro owner out!
And let me know if it works!!!!
Old Mar 28, 2010 | 10:38 PM
imcdowel's Avatar
ill definitely keep you guys posted i appreciate the tips. but i have to paint most of the car parts still attached. it was hit by a Tahoe a while ago and the insurance was gonna total it but i refused and took my losses. i molded the frame and body to fit again but i had to pin the fender and front bumper on were there previous drill holes were so its stuck... rest can come of though. if its that easy to paint maybe ill see how the bumpers and fender goes. then ill man up and do the whole car. thanks again.
Old Mar 29, 2010 | 12:04 AM
imcdowel's Avatar
one more thing, i will buy full exhaust in the near future but till then how would i paint the tips chrome? i figure same process but i cant find high temp chrome paint. any links?
Old Mar 29, 2010 | 12:08 AM
  #20
Let me offer a little help before you end up having to paint it twice. The instructions in that link are a bit amateurish. First of all, they're referring to a fiberglass bumper, you have urethane which is different. Try to avoid using bondo on the bumper. If it ever flexes (the bondo won't), off comes the bondo taking paint with it. Also, you don't sand the finished paint starting with 220 grit, holy crap! Use 1200 grit first, then finish with 1500 if you feel 1200 isn't good enough. If you have some high spots (runs) you can take it down with 600, then follow up with 1200. On one of my previous Vette restos, I spent about 40 hours just wet-sanding and power buffing the new paint. I used 1200 and the job turned out like glass. It takes experience to do it right without burning through. But, you gotta learn somehow, and it sounds like you want to learn. Another thing, do not sand the color before applying the clear, unless you absolutely have to like for removing a run. Base paint doesn't have a hard surface like the clear does, so it's easy to cut right through it...oops! Plus, if your color coat is a metallic, sanding it will bring the metallic out too strong, making it look blotchy and off-color. And do not use any chemicals on the color before the clear, that's asking for troubles with the clear. Just use tack cloths to remove any lint, etc. If the cracks you're referring to on your bumper covers are just the paint, you really want to strip the paint off. Paint is popping off because the bumper was flexed excessively. It's very likely that more of the paint that is still on there is not completely adhered anymore. That'll be something else to come back and haunt you if you leave it alone. If the cover itself is cracked, you may be able to get it mended (welded by melting together). Otherwise the only "right" way would be to replace the bumper cover. Ask anybody who works with paint, and they'll tell you that 90% of a good paint job is in the prep work.
