overheating help
overheating help
my car keeps over heating. i have coolant no leaks the thermostat is new and the electric water pump wired to the ignition fuse. i can hear the pump come when i turn the ignition on. if im correct i should jus need to check the coolant thermostat and pump for my source but all seem to be good. ima remove the thermostat and see what happens. any other suggestions. i gotta have it fixed by tuesday in time for work
Make sure you have all the air out of the system... If i have air in mine my gauge will give all kinds of crazy readings. Parking on a steep hill or jacking the nose of the car up as fas as possible when you are bleeding it helps.
when is the last time it had a coolant flush? if it has been a while, now might be the time to flush the entire system.
drain it, flush it in sections with a garden hose, put it together, fill it properly, bleed it, drive it, top it off, bleed again... should be good after that point as long as your pump and fans are working properly
is the engine throwing any codes? running lean maybe?
i think my problem is another blown head gasket. I was flushing the coolant with a water hose and its still getting hot steam started to come outta the radiator and i got moisture and black stuff comin outta one pipe. and i put some oil on on the hot header and it bubbled. i dont have a drain pan to actualy check to c if its milky what was on the dip stick looked fine.
