LT1/LT4 Tech 1993-1997
Overheating got my stumped
Old 01-13-2011, 05:19 PM
timing chain is most likely fine. lt1 has a good stock chain. never heard of one jumping a tooth. water pumps are good to, the only thing they do when they go bad is leak a bit off coolant. still pump. never heard of a lt1 water pump not pumping. how does everything look? any crudd in there? did you clean and dry the opti right away? i would certainly change the opti if i had a new water pump and had it apart, thats of coarse if the opti is old. new plug wires would be easier to install now as well.
Bad2TheRooTS's Avatar
Also I was under the impression their would be two o-rings...one on the pump shaft and on on the shaft coming from the block. When I took the coupling off I only had the o-ring on the pump. Problem?
Old 01-13-2011, 05:21 PM
check inside the coupler.
Old 01-13-2011, 05:39 PM
Not sure how old the opti is. I just bought the car last week with 70k miles. I think I will go ahead and change it...even though that's more money.
Yeah well I was WOT when I heard a screeching from the engine...after that I couldn't get any coolant to flow through the system. All signs point to a messed up water pump. Unless there's somthing else?!
Old 01-13-2011, 05:55 PM
It wasn't too bad but there was some oil built up on the top of the water pump and even some signs of it on the drive shaft
Old 01-13-2011, 08:30 PM
screeching at wot is usually a belt or belt tensioner. your using a new thermostat right?
Old 01-14-2011, 08:35 AM
Yeah. I kinda decided while its apart to just change everything I'm uncertain about.
Got a new timing chain, waterpump, thermostat, radiator, radiator cap, MSD Opti spark, spark plugs and spark plug wires, drive belt, an belt tensioner.
Well....I hope that fixes the problem. Lol
Old 01-14-2011, 09:23 AM
rmoncur's Avatar
Did you light some 20's on fire for fun as well...lol...sounds like she is already eating holes in your pockets.
Old 01-14-2011, 10:05 AM
LT1ChevyBoy's Avatar
well good news is that msd optispark is great and the entire side of our motor is gunna be like brand new so you wont have to worry too much i would say its easier just to replace when buying used just to put mind at easy then to just hope everything is ok
  #20
Old 01-14-2011, 10:40 AM
you realize that you will have to drop the front of the oil pan to get the front cover off. been there done that.
Quick Reply: Overheating got my stumped
