OVER HEATING
OVER HEATING
my 93 z28 has be overheating for the last couple of weeks. i changed the thermostat and my fans work so idk what it is. my friend used to have a camaro and he said its cuz im missing my airdam. what do yall think. i was think of replacing the water temp. sensor
RE: OVER HEATING
when im driving but its weird cuz i can be at a light and then the temp is fine. i never had the air dam. it would always overheat but as long as i had the ac or any other fan on it would stay cool. it dont wanna work that way anymore for some reason.
RE: OVER HEATING
Well you are certainly on the right track, you need to check your water pump, becaue it may have gone bad. But before you do, you must reinstall your air dam back, because that is most likely the reason why its happening
RE: OVER HEATING
The air dam can cause it to get hot very quickly without it. I test drove my car after fixing and left the air dam off cause I was in a hurry and it heated up.. put it back on and didn't have the problem again. Your water pump could be going bad, check and see if water is leaking out the back of it.
RE: OVER HEATING
do you guys know a site that sells a new one for a decent price or should i call the dealership to see if they have it? i seen a used one on ebay for 15plus shiping so if i cant get one at a junk yard or something il buy it from ebay
RE: OVER HEATING
check first on the side of the water if its leaking if its not then most likely thats not the problem check hoses for restrictions thats what happened to me i ran out of choices and booomed there it was a plugged aluminum hose that runs behind the the heads.....it could be something sample too check for air pockts
