Oval Pipes
Hello everyone
I have a 95 Z28 and I want to install true duals. However, since I already lowered my car almost an inch, clearance has become an issue. So, my buddy suggested just doing oval pipes. Has anyone had any experience with oval pipes, and suggest a company that produces oval pipes and mufflers?
I've seen oval pipes before, but never a muffler with oval inlets and outlets. I'd suggest (when you find the oval piping) that you do your true duals out the back, and once you're beyond the rear end change back to round pipe. Then put two small mufflers where the stock one used to be (you could do a GMMG configuration, or two small mufflers before each tip).
