LT1/LT4 Tech 1993-1997
optispark fix
Old Mar 6, 2011 | 08:19 PM
chazpizzaz's Avatar
Default 94 z28
i need to swap out my bad optispark for a new how do i get everything lined up never messed with one before
Old Mar 6, 2011 | 08:31 PM
chazpizzaz's Avatar
Default optispark fix
how do i replace my bad one how do i get everything timed right
Old Mar 7, 2011 | 11:49 AM
greenarrow's Avatar
September 2009 ROTM
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
Amazing what a google search will reveal. And I'm sure if you searched the forum you would of found about 100 threads on the subject as well.
Old Mar 7, 2011 | 12:27 PM
the shaft on the opti is spined with one gear misssing and lines up with the cam spline with the missing gear. it only goes on one way. do not use the mounting bolts to pull the opti on, you should be able to push it and have it slide on. its also a good time to change the seals on the front cover.
http://shbox.com/1/93-94_opti.jpg
Old Mar 7, 2011 | 01:07 PM
Massey's Avatar
replace the water pump while you are at it too. A failed water pump can kill an opti fast. Since it has to come off anyway why not, it is just piece of mind. Oh and get new if you can, remanned makes me nervous on these pumps.
Massey
ricer_killaZ28
Aug 9, 2010 08:53 AM
luvmysccamaro
Dec 28, 2007 01:19 PM
luvmysccamaro
Dec 26, 2007 04:04 PM
whitebread96
Dec 15, 2007 12:09 AM
