LT1/LT4 Tech 1993-1997
Opti what
Old Nov 24, 2006 | 06:19 AM
95redcam's Avatar
Default Opti what
Is there a difference between the stock oem distributor and the mds?
Old Nov 24, 2006 | 11:40 AM
shnormo's Avatar
Default RE: Opti what
The MSD HEI coil has a higher coil voltage with less primary and secondary resistance. If it has an ignition module, it is a performance one that is more accurate. The internals are made from higher grade materials and the cam gear is also stronger. It has less resistance on the posts too.
Old Nov 24, 2006 | 10:08 PM
95redcam's Avatar
I bought a new cap and rotor along with some new wires because of some ignition problems. Should I have gone with the whole package and got the distibutor as well, or is it usually just the cap and rotor that needs replacing?
Old Nov 25, 2006 | 12:58 AM
When dealing with the optispark it is best to change the entire assembly. The problems are mostly with the internal circuitry.
ztwentyate
Aug 25, 2015 01:33 PM
Z28Freak
Apr 24, 2011 02:02 PM
wicked94z28
Jan 31, 2011 12:36 AM
sbcman25
Jan 29, 2010 02:01 PM
chadillac4110
Aug 18, 2009 07:41 PM
