LT1/LT4 Tech 1993-1997
opti spark
Old Jul 20, 2008 | 01:01 PM
camarorz28's Avatar
Default opti spark
is it necessary to find TDC in order to change the opti spark? what will happen if TDC is not found before the removal of the opti spark??
Old Jul 20, 2008 | 01:53 PM
Default RE: opti spark
Makes no difference. It only goes in one way, but you must make sure not to force it. There is a difference on how the vented and unvented key in. Get a repair manual to be sure.
Old Jul 21, 2008 | 10:33 AM
camarorz28's Avatar
oh okay thanks pete, well i remove my old opti spark and install another one, the car still does not start! i'm going to check for spark coming out of the distributor!
Old Jul 25, 2008 | 10:56 AM
camarorz28's Avatar
what happens to the optical sensor when moister is present, other than not allowing to distingush the slotted? does the optical sensor burn??
hyozanryu
Jun 15, 2013 06:43 PM
bd92rs
Sep 26, 2011 11:17 AM
nash211
Jan 15, 2007 05:42 PM
ufnwish
Oct 8, 2006 06:38 PM
kwest
Jun 13, 2006 09:03 PM
