LT1/LT4 Tech 1993-1997
oil pump drive gear
Old Nov 7, 2011 | 12:40 AM
94z28chevy's Avatar
Default oil pump drive gear
i pulled into my driveway yesterday only to watch my motor lose oil presser after i put a new deep sump oil pan, new high volume oil pump, new drive gear, and new sending unit. to do this i pulled the motor last winter and put a bigger cam in it also. well it took me a while to get the car on the road this year after my 6speed swap. so at first i was hoping it was the sending unit but after pulling it off and putting a mechanical oil pressure gauge and presser still reading 0 i pulled the intake and all the teeth on my oil drive gear was gone the only thing i can think of is the teeth on my Comp cam 280 XFI cam #07-467-8 dont line up with my stock replacement oil pump drive gear
so my ? is has anyone else had this problem and if so how do i fix it
Old Nov 7, 2011 | 07:28 AM
this is the first i have heard of this issue. did the old drive gear go to pieces or just the new one?
Old Nov 7, 2011 | 08:05 PM
94z28chevy's Avatar
the new one is the one broke the old one i junked when i replaced everything i will get pics of it up tomorrow
Old Nov 7, 2011 | 10:11 PM
if the housing came apart you could use one of these. https://www.herronperformance.com/st...&productId=317
Old Nov 7, 2011 | 11:18 PM
94z28chevy's Avatar
the housing is fine its just the gear
Old Nov 8, 2011 | 07:49 PM
numskull223's Avatar
I know this sounds crazy, my oil pump locked down and stripped the teeth off the drive gear. I pump in a new oil pump and and I was not about to buy a gear for the lt1......advance wanted 57.00. So I had plenty of older sbc 350 gears, So I made a sleeve to fit inside the gear as a press fit......knock on wood I havent had a problem yet.
Check that oil pump.
Old Sep 17, 2015 | 03:45 AM
94z28chevy's Avatar
posted samething in two threads sorry
Last edited by 94z28chevy; Sep 17, 2015 at 06:18 AM. Reason: posted samething in two threads sorry
Old Oct 11, 2015 | 03:40 PM
cardo's Avatar
Old thread yea. But a common replacement part for LT1. Curious what options for the OP drive are still available? Cant get the Herron page to load. I think the stock part is still available from GM. I guess in worst case we can use a gutted sbc distributor.
Also who sells the metal/aluminum coupling/busing/retainer? All i find are the nylon couplings.
Old Oct 11, 2015 | 06:20 PM
94z28chevy
Sep 20, 2015 08:03 PM
mab6680
Jun 29, 2013 07:15 PM
Chia219
70-81 Transmission & Differential
Mar 2, 2013 07:05 PM
riss1978z28
May 21, 2012 02:27 PM
Jr. Mechanic
Nov 11, 2009 06:52 PM
