oil cooling lines
oil cooling lines
the lines that come from the oil filter housing, is thier a way to block or make that line a loop so you dont have to use it or is it important for the lines to be used. if so where can i get the lines?
no i just dont have it and it seems like a hassel to get the tubing for it. im also having alot of trouble finding front brake lines i called this company and they sent me a brake hose kit but its not even close to long enough to replace the front lines. also it came in the section of hosing about 12inches long
isnt that for the flex hose between the caliper and the fitting. have a look at what rsm has, they may have the stock one. the place is a bit spendy but you get oem parts. gmpartsdirect is another place to look.
Go to a place that makes high pressure lines and they will make you brake lines. My dad did it for his truck and we live in a little ol hick town, so, there should be somewhere like that where you live. The can make a line that will fit anything.
yea it is the flex house betweem the caliper so im just gonna send it back but ill check those places out. there used to be a place that did brake lines but i guess they closed but ill do a little more digging
cbutler820
03-24-2012 10:54 AM
