LT1/LT4 Tech 1993-1997
oil
Old Jul 5, 2006 | 05:26 AM
kyleb's Avatar
Default oil
i have a '95 z28...what kind of oil do i use? i know with my saturn i had to use 15/35. what kind do i need for my camaro? thanks!
Old Jul 5, 2006 | 07:09 AM
Saint_Ali's Avatar
Default RE: oil
you can use sae 5w-30, sae 10w-30, or sae 30
Old Jul 5, 2006 | 12:59 PM
SLJ2137694's Avatar
Default RE: oil
If you have a stock engine you will always do better using what the owners manual recommends for viscosity. Heavier weight oils should be used where bearing clearances have been set loose for extreme duty. I also highly recommend a synthetic oil be used. Your owners manual probably recommends a 5W-30 or 10W-30. Straight 30W is way too heavy for a stock engine and will tend to flow poorly when cold and starve bearings of oil on start-up.
ORIGINAL: kyleb
Old Jul 5, 2006 | 02:46 PM
akohnz's Avatar
Default RE: oil
Retired huh? Sounds like you had a good job. Thats exactly what Im going to school for, I have always wanted to work for GM. Ive had my camaro since I was 16 and ever since then Im hooked! Where did you go to school, got any suggestions that would help me with my career? Thanks!
akohnz
Old Jul 6, 2006 | 11:39 AM
SLJ2137694's Avatar
Default RE: oil
Sent you a PM.
ORIGINAL: akohnz
akohnz
