LT1/LT4 Tech 1993-1997
o2 sensors w/ headers.
Old Nov 6, 2011 | 10:08 PM
RFxCamaro's Avatar
Craby is right about the resistance with solder. It usually only happens with bad soldering. Make sure you keep the iron hot and don't heat the solder heat the wire and place the solder on the opposite side and let it flow in. The only time the solder should touch the iron is to tin the tip before you solder.
Old Nov 6, 2011 | 10:22 PM
Catmaigne's Avatar
If you form connections properly without damaging the sensor itself (by using a heatsink) and insulate the readings should be unchanged. The change in resistance through soldering is nominal because the tiny globs dissipate very little current as heat.
Old Nov 6, 2011 | 10:42 PM
the 02's read .2 to .7 volts. low volts
Chevra
LS Series Tech
May 25, 2014 05:38 PM
Chevra
Apr 4, 2012 11:59 PM
dmoneey05
Feb 26, 2012 11:03 AM
aslopez1986
Mar 24, 2011 01:03 PM
dutinsss
Sep 18, 2007 05:47 PM
