LT1/LT4 Tech 1993-1997
Not sure what the problem is
Old Jun 13, 2011 | 03:10 PM
fatboyrider2004's Avatar
Default Not sure what the problem is
I have a 1997 camaro. the starter turns over, the engine runs but acts like its starving for fuel. When I give it a little fuel, she stops running. There are times when she just runs with out a problem. Tuned it (Spark plugs & distributor cap & rotor) also replaced the fuel filter. No check engine light or codes to down load to identify/pinpoint the problem. Any thoughts.
Old Jun 13, 2011 | 04:02 PM
x01660's Avatar
The Mustang Hunter
Ohm out your coil and test the Ignition Control Module (ICM). Autozone tests both for free.
Good luck and kill Rustanks!!!
x01660
Old Jun 13, 2011 | 05:28 PM
Since it acts like it's running out of fuel, have you checked to see if it is running out of fuel? Check your fuel pressure, could be either your fuel pump going out, or a bad pressure regulator.
Old Jun 13, 2011 | 07:15 PM
^^^ agree fuel pump or regulator, or your actually out of gas. where is the gage at. some of the 4th gens will run out at just under 1/4 tank.
Old Jun 13, 2011 | 07:26 PM
^ You can say that again....oh you did!
Old Jun 13, 2011 | 08:27 PM
lol... and pooff its gone. dang i been double posting on almost every one here lately. last time it did that the site went wack for a while.
Old Jun 13, 2011 | 10:29 PM
The site's been wack for me lately too. Click on reply and sometimes wait........and wait........then click reply again just to make sure it takes. lol
My guess is maybe that's where the double posts happen?
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
