LT1/LT4 Tech 1993-1997
Newbie - first Camaro - HELP!
Old May 28, 2006 | 07:21 PM
tool_man's Avatar
Default Newbie - first Camaro - HELP!
Just bought 96 Camaro Z-28 convertible, cleaning up a few things under the hood. SES light was on, found short in wire to MAF. Still have P0200 and P1222 showing, how do I test injectors? Also, found a purge valve (i think that is what it is) on the front drivers side of the engine (i noticed there is also one on top of the engine). The electrical is hooked up but both vac lines go nowhere, I can't find anywhere to hook them to. Any help much appreciated.
Old May 28, 2006 | 07:56 PM
SickSickSick's Avatar
Default RE: Newbie - first Camaro - HELP!
Without High Dollar Equipment It's Hard to Test Injectors. If Your Just Trying To Find Out If Each Is Firing You Can Use A Mechanic's Stethoscope Or A Long Screwdriver. You Can Put the Tip On Each Injector With Your Ear To The Handle You Should Hear A Clicking Noise. That is The Solenoid Operating. You Can Check The System Itself by Using A Noid Light. Plugging The Noid Into each Injector Connector ... Start the Engine And The Light Should Flash. Sick
Old May 28, 2006 | 08:51 PM
94Z28SHAKER's Avatar
http://shbox.com/1/vac_check_valve.jpg
heres a pic of where the vac check valve is supposed to be,
and here is a pic of the vac canister with check valve port http://shbox.com/1/vac_tank.jpg
heres where the tank mounts http://shbox.com/1/vacuum_tank.jpg
and this is where the purge canister valve is located http://shbox.com/1/evap_sol.jpg
Old May 28, 2006 | 09:02 PM
does that help at all or do you need more info?
Old May 28, 2006 | 09:07 PM
tool_man's Avatar
That's great, it's the same valve that's on the top of engine (purge canister valve pic) but it's on the drivers side kind of by the opti on a bracket. The wiring is hooked up but both vac lines are just hanging there.
Old Jun 1, 2006 | 10:04 PM
are you talking about your opti vac lines?
if so here's an illustration http://shbox.com/ci/opti_vent.jpg
and here is a picture http://shbox.com/1/opti_vacuum_harness.jpg
hope that helps, good luck.
Old Jun 2, 2006 | 12:07 PM
akohnz's Avatar
hey where do you find all those illustrations, is it a website? Ha nevermind, I saw the link on your post, my bad
akohnz
kuhlman187
Nov 17, 2014 05:58 AM
Mony Montana
Jan 10, 2013 03:04 PM
bigjoeblaze
Apr 12, 2009 08:16 AM
Aces
Jan 24, 2009 02:08 PM
jarcat146352
Sep 9, 2004 10:52 PM
