New wheels
New wheels
Ijust got the zo6 wheels for my 1995 camaro there 17x9.5.I don’t have the tires on them yet but when I opened the box they look pretty wide. So I went out and put one on (just the rim) and there’s nothing hitting but its real close.I have some tires already ordered there 275/40/zr17.I see that some of you guys have the rims on your cars. So my question is, is there going to be any rubbing whenI put them on? Should I just get the spacers now so when I get the tires I have no problems? Any advice will help. Thanks!
RE: New wheels
No, as long as they are not an actual take off from a Corvette they should be fine. The aftermarket replica wheel companies make them to fit the F-bodies as well. You're not going to run into any rubbing in the front, although I wouldn't go any wider than what you have, and in the back you can run up to an 11" wheel with a 315 tire on it before you start getting issues with rubbing. Enjoy the wheels!
