LT1/LT4 Tech 1993-1997
New heads or stock heads?
Old Oct 27, 2009 | 03:56 AM
SixShooterCamaro's Avatar
Question New heads or stock heads?
Alright guys I have the 350 roller motor from my friend, I just stripped it to bare block... So now im getting the rotating assemly kit for a 355 setup and want to do 58cc heads on it running around 10.5:1 compression with flat top pistons...
My question is should I buy new heads with a cam kit or should I use the heads on the block and have them ported, I heard of this guy who does the heads who is well known on this site and im not sure who he or they are...
By the way im having the machine shop bore it .030 over to a 355... I figured a 383 bore would leave the walls to thin running into overheating problems...
So what should I do with heads and cam work? well mainly heads because Im most likely getting this:
Comp Cam
"XFI" 280 Hydraulic Roller Camshaft
GM LT1 & LT4 350ci 1993-96
Lift: .576"/.570" w/1.6 Rockers
Duration: 280°/288°
RPM Range: 2000-6000
I own a 96 Z28 OBD-II
Old Oct 27, 2009 | 08:25 AM
whammer3024's Avatar
ROTM Winner
you need to do more research before you start in on a build like this.
that said...a 383 and a 355 have the exact same bore...4.030. the stroke is what will make them different. a 383 uses a 3.75 crankshaft and a 355 uses the stock 3.48 crankshaft. therefore, a 383 and 355 are pretty much the same "safe-wise".
there are a couple people out there that are considered the guru's of head porting. lloyd elliott and advanced induction. they can port the crap out of stock heads and get you anywhere you want to be. they can both also help you spec a cam to match your goals.
www.advancedinduction.com
www.elliottsportworks.com
Old Oct 27, 2009 | 05:35 PM
So what would you do displacement wise? I think im gonna go with the 355 setup... I thought the 383 has a .040 to .060 bore... I guess not if you have the stroker kit but then how much more would the stroker kit be you know?
Yeah lloyd elliot thats who it was... Im thinking about using my stock heads, it would certainly be cheaper wouldnt it?
Another thing is you said I need to do more research, I thought I had it figured out but now im lost again, where the heck do I start? what parts do i need?
Old Oct 27, 2009 | 05:55 PM
its not clear to me what block are u planning on puting in the car. is it a lt1 or ls or a regular small block chevy motor.
Old Oct 27, 2009 | 07:45 PM
im not sure it came out of an early 90 blazer... all I know its a 350 SB roller motor
Old Oct 27, 2009 | 07:48 PM
ROTM Winner
okay..wow...you just totally destroyed everything i said since we are NOT talking apples to apples here.
i was under the assumption we were talking LT1, but since we're not, lloyd elliott won't be much help to ya with your heads. i, personally, would not be putting that motor in your car. i'd stick with an LT1 but to each their own
I am really in the dark in this and I would appreciate some help, I can always go to a machine shop and be like ok here is the money and do it butI dont want to be over charged... I have basic knowledge but when it comes to machine work and rebuilding I know nothing about it... I have the money to do this within the next couple months for the whole setup...
Old Oct 27, 2009 | 07:49 PM
383Stro's Avatar
You need to work on that lt1 block and leave the blazer's 350 in the blazer. Simple as that, you are giving me your headache! LOL You will see what i mean if you dont stop while you are ahead still. Beware the sunken costs...dont let them drive you farther and farther in THIS IS YOUR CAUTION>
This way to sunken cost city<<<<<<<>>>>>>> Just dont get into a fight with the emissions man.
Old Oct 27, 2009 | 07:50 PM
What is the gain of having an LT1 if im doing a complete rebuild though? I mean I was under the assumption that as long as it was a 4 bolt main I would be in good condition
Old Oct 27, 2009 | 07:52 PM
I got the motor for 150 bucks so im not out too much on it... it be nice if I can find an LT1 for around that price but I highly doubt it
