LT1/LT4 Tech 1993-1997
New guy with a question....
Old Apr 17, 2006 | 01:39 PM
iknowiknow's Avatar
Default New guy with a question....
Hey everyone, i am wondering if buying an aftermarket Granatelli Mass Air Flow Sensor is actually worth the moeny along with a JET Performance Chip? Does it make a noticable difference or would you recommend on putting the money somewhere else for now?
Thanks
Old Apr 17, 2006 | 05:34 PM
Default RE: New guy with a question....
Unless you are planning to do some internal engine mods, the stock MAF sensor is more than adequate. Use your money to buy a cold air intake kit and you will get better results. Also, 94 & later Z28s do not take performance chips, the computer wil have to be reprogrammed. You can send your PCM to a tuner like PCM For Less, tell them about your car, and they will reprogram your computer and send it back to you. Between the CAI and the PCM tune, you should pick up around 30HP.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
