LT1/LT4 Tech 1993-1997
new chick with camaro problems LTI 4th gen
Old May 4, 2010 | 05:36 PM
  #21
whammer3024's Avatar
ROTM Winner
Originally Posted by 383Stro
The regulator is stuck in the oil pump.
you know that for sure? or are you guessing? because i don't see how you can get to that assumption with the limited information we have
Old May 4, 2010 | 05:56 PM
  #22
383Stro's Avatar
I am assuming that people know what the normal range of oil pressure should be with their cars...if they are having a problwm with the oil pressure fluctuating rapidly with acceleration, then yes I can deduce that the regulator in the oil pump is stuck, I have seen it on three occasions. Usually the increase on acceleration is great and results in the car beginning to leak as seals are pushed out by high oil pressure.
Old May 4, 2010 | 06:00 PM
  #23
383Stro's Avatar
I should have included that a little fluctuation is normal and that the regulator's job is to stabilize oil pressure....now dont run out and change your oil pumps because I said fluctuation is undesirable... a little is normal even like 10-30, but more than that and you are having regulator issues.
Old May 4, 2010 | 08:28 PM
  #24
r6rider's Avatar
welcome to the site. it sounds like you should give the opti a change regardless and see what happens, couldnt hurt well except maybe your wallet
Reichilu
Mar 18, 2008 03:08 PM
Underfire05
May 7, 2007 04:43 PM
xangryangelx
Mar 29, 2007 11:36 PM
IrocZ28_Ladee
Aug 17, 2005 08:54 PM
