LT1/LT4 Tech 1993-1997
need power
Old Feb 20, 2007 | 07:29 PM
95z281LE's Avatar
Default need power
I was wondering what the best way to get into the 11s is woth a 95 z28
Old Feb 20, 2007 | 07:44 PM
Default RE: need power
You will need to do all the bolt on stuff, stroker kit, big cam, big rear end gears, beefed up tranny, high stall converter if auto, drag slicks, spool, subframe connectors, stiff LCAs. If this does not do it, a shot of nitrous will help.
Old Feb 21, 2007 | 12:37 AM
95z281LE's Avatar
What would need to be done to the trans if i have a T-56
Old Mar 16, 2007 | 04:12 AM
INTENSE_Z's Avatar
if you want consistancy find or get an automatic. 4L80e works good. nitrous does wonders also if youve done the correct beefing of the lower end
MaxTheKiing
Aug 23, 2010 03:21 AM
rbeard
82-92 V8 Tech
Aug 9, 2009 12:11 AM
dkblind87
LS Series Tech
Jul 27, 2009 05:35 PM
IBADRIDE
Jul 13, 2006 01:44 AM
