LT1/LT4 Tech 1993-1997
need new rear end, help. (1996 Z28, 6-speed)
Old Mar 16, 2010 | 11:50 AM
redemption91's Avatar
Default need new rear end, help. (1996 Z28, 6-speed)
hey, my stock 3.23's are chewed up and it's time to do something about it. i want to rebuild my rear end to a 3.73 (or maby i don't, you tell me). what do i need to do to make this happen? do i need a new carrier (like some are saying in other posts)? please help! by the way, i have a 1996 Z28 camaro w/ a 6-speed T56 (stock).
Old Mar 16, 2010 | 01:34 PM
whammer3024's Avatar
ROTM Winner
the carrier should be the same. i think a 3:73 is weak for a 6 speed car. i believe most people go for 4:11 gears but you could do 3:73 if you want
Old Mar 16, 2010 | 11:24 PM
u would be better off to pick up a whole rearend if u can find one. 342 or 373s. if u want to change the gears get some books and do the research. alot depends on what u use the car for. if u want a little more pull but dont want to lose mpg then go with 342 or 373, if u dont do alot of freeway driving at 75 and dont mind losing your mpg then go with the 411 like wham says. u will have neck snapping torque.
Old Mar 17, 2010 | 04:24 AM
AmirGTR's Avatar
Newbie here, just wondering what your rear end does that tells you it's all chewed up cause my rear end makes some weird noises too especially when I'm backing outta the parking.
I heard 4:11 really kills your gas mileage so think about that before you go for it, and also if I were you I'd get something more durable than that 10 bolt, maybe a 12 bolt or 8 bolt in which case yeah you'd need a new housing.
Old Mar 17, 2010 | 01:04 PM
imcdowel's Avatar
what is all needed for a 10 bolt 4.11 rear end set up, mines pretty much much dead. post links or any help.
http://www.summitracing.com/parts/RMG-GM82411/
Old Mar 17, 2010 | 06:35 PM
Default help.
so, if i were to look for new gears, what would i search under (parts wise) in like a site suck as jegs or summit racing? what is the technical term for gears? also, do i need to do anything whatsoever to my car or just simply replace these "gears?" thanks.
Old Mar 17, 2010 | 07:14 PM
ring and pinion. if u toasted the one u have and want to reuse it would be a good idea to replace the bearings and races. i would think the axle bearings would be good but u would want to look at them. setting the gears is a precise job and is easy to mess up, u need to get them just right. thing is u dont know if u got it right most times till its to late. thats y i was saying do lots of research.
Old Mar 18, 2010 | 10:19 AM
thanks for the help, i will have my local mechanic help me find out some more about my project. i think im going with the richmond 3.73, but what is the difference between the 2 series and the 3 series?
Old Mar 18, 2010 | 12:25 PM
Stillborn's Avatar
If you got the cash 373s and a ligenfelter rear end ur going to have to try and break that b*tch.
Old Mar 18, 2010 | 02:26 PM
will i be fine if i keep my rear end, but throw richmond 373's in it? i don't want to change anything but the ring and pinion.
RFxCamaro
Jan 29, 2011 05:47 PM
96ZLT1
Oct 12, 2010 09:47 PM
briggette
Jul 25, 2007 08:04 PM
us11csalyer
Jul 17, 2007 10:12 PM
