LT1/LT4 Tech 1993-1997
Need help with sub frame.
Old Oct 30, 2010 | 04:31 PM
Brandon96z28's Avatar
Default Need help with sub frame.
ok i recently feel asleep and ran off the road, i bent my lower a arm, the knuckle the the sway bar mount, i got the sway bar back to normal and need help with the sub frame. Right where the left part of the a arm goes in the sub frame is bent back about two to three inches, i am short on cash and would love for someone to help me to figure out if i could possibly bend it back to normal. if anyone can help i would love it..... thanks and i hope to see if anyone can help!
Old Oct 30, 2010 | 06:10 PM
the a arm is bent or the frame is bent? if the frame/unibody is bent it will take a frame machine to fix right.
Old Oct 30, 2010 | 11:41 PM
both but i got a new a arm, i found someone with the front uni body or sub frame i really dont know the diff, it has both stuts and rack and everything. i know there is only about 4 or 5 bolt a side but idk how hard it would be to change. plus idk if i want to go though the trouble if it s not gonna cost aot to get it bent back
Old Oct 31, 2010 | 01:23 PM
It will be safer if you just replaced it, as there may be more damage than is visible to the naked eye.
Old Oct 31, 2010 | 06:15 PM
so long as its from a z28 93 to 97 (i think) it would be cheaper and safer to change like pete is saying. you will have to jack stand the front body up, then hook on to the the motor with a cherry picker to hold it up, then unbolt the k member from the motor and the body and drop it. unhooking brake lines and such that you wish to keep. thats a simplified explanation. lol.
Old Nov 12, 2010 | 02:45 PM
thanks guys i just found a wrecked z28 and it has all i need thanks for the help
Old Nov 12, 2010 | 08:15 PM
THere is a chance the body or body mount areas are "tweaked". If it is tweaked your going to have problems getting the replacement Kmember to fit. If it will install the next step is alignment. If it can be aligned its all good to go. If the alignment guy says he can not get it back to spec its off to the frame machine.
pimnmike
Jan 20, 2011 08:41 PM
cadfleet
Mar 7, 2010 08:38 PM
benz660r
Sep 18, 2006 05:50 AM
hugo_a2003
Sep 1, 2006 06:43 PM
chevy072981
Jun 6, 2006 04:56 AM
