LT1/LT4 Tech 1993-1997
Need help!!! Car idles then dies
Old Jul 29, 2012 | 01:48 AM
Jelz28's Avatar
Ok, replaced my iac and fuel filter so I'll see if that fixes the problem. I'm thinking I may have a crappy "racing" electric fuel. when I roll both windows up at the same time, I can hear the pump get quieter like its losing power. So maybe that's it.
Old Jul 29, 2012 | 12:45 PM
Greg08's Avatar
stick a fuel pressure gauge on the shrader valve.
Old Aug 7, 2012 | 12:53 PM
Jelz28's Avatar
Going to check fuel pressure later. Changed my fuel pressure regulator, fuel filter, iac. Still doing it! I have the crankshaft sensor code on, and a twc low efficiency bank 1 p0420b code. Could a 02 sensor be the issue?
Old Aug 7, 2012 | 12:55 PM
Jelz28's Avatar
Its after my car warms up also the egr code or whatever.
Old Aug 7, 2012 | 04:00 PM
The codes you are getting could very well be the cause of your problems. Low efficiency means the cat is bad, and it could be causing excessive back pressure. The EGR code, depending on the DTC, could also cause the engine to die, especially if the EGR is stuck open.
Old Aug 7, 2012 | 10:56 PM
Jelz28's Avatar
So how can I test these things?
roughneck
Feb 13, 2014 10:17 PM
The Emperor
82-92 V6 Tech
11
Sep 16, 2013 06:30 PM
Hockinjm
Mar 24, 2012 09:33 AM
shinwolf14
Jul 23, 2011 04:18 PM
peter
Feb 28, 2008 07:03 PM
