LT1/LT4 Tech 1993-1997
Need help...
Old Jan 15, 2012 | 06:56 PM
5mok3z28's Avatar
Default Need help...
Hey guys well I got a new optispark and MSD coil for my 94 z28 it took me a while but I finally put everything back in but when I start the car it turns on fine but has a sputters idle and when I try to give a lil gas it wants to shut of...I really need some help so any suggestions will help...oh I also put new spark plug wires and spark plugs I gapped them at .050 thanx guys....
Old Jan 15, 2012 | 07:27 PM
BasicConcepts's Avatar
Technical User
are you sure the plug wires are where there supposed to be
Old Jan 15, 2012 | 07:33 PM
5mok3z28's Avatar
Yea I made sure to mark all of them before putting them on its wierd jus it turns on kinda wired and I can floor the gas and it won't rev up it just wants to shut off...
Old Jan 15, 2012 | 07:38 PM
Technical User
triple check the wires and also make sure all your vac lines are hooked up
Old Jan 16, 2012 | 10:33 AM
look here for proper plug wire location http://shbox.com/1/opti.jpg
Old Jan 16, 2012 | 12:11 PM
torque_is_good's Avatar
if you are absolutely, beyond a shadow of a doubt positive that
all of the plug wires are good
none of them are out of order and are on secure
none of the spark plugs has a cracked insulator
then.............
remove optispark and re install correctly because the timing is off
