LT1/LT4 Tech 1993-1997
Need to get her running right before a road trip in a couple months....
Old 04-06-2012, 02:40 PM
334SRED96SS's Avatar
Originally Posted by craby
got all the linkage unhooked and all that. should come out if you got the four long bolts in the corners.
I got it off and cleaned up... Now it don't want to run with the MAF plugged in...
  #22
Old 04-06-2012, 02:44 PM
test it. be right back, ok look here at number 7 on the list https://camaroforums.com/forum/93-02...rt-here-38462/
  #23
Old 04-07-2012, 01:23 AM
Maf is good... I guess I'll see how it runs tomorrow... Forgot to grab the car seats in order to take a cruise...
  #24
Old 04-08-2012, 09:50 AM
So got her out for a ride yesterday with the MAF still unplugged and it ran awesome and didn't throw a code... I am changing the power steering lines next weekend... I helped a buddy change a radiator last night in his Mustang ( that has $30,000 just under the hood.). He loves the sound of the slp with the 40 series...
  #25
Old 04-08-2012, 10:20 AM
i would think the maf is failing somehow if it runs better with it unplugged.
  #26
Old 04-08-2012, 12:06 PM
I will grab another one soon along with the temp sensors and a few other odds and one... I need tranny mounts and header bolts... Any suggestion for the tranny mounts and MAF...
  #27
Old 04-13-2012, 05:16 PM
Tomorrow I will be putting my power steering lines on, coolant flush, changing the ECT, cleaning the MAF, and thermostat
  #28
Old 04-13-2012, 11:34 PM
pick up a stock trans mount, there like 15 bucks and not hard to put in. make sure to use maf cleaner on the maf. see what rock has for price and product and you can compare the local stores prices. standard and acdelco are good oem parts, ive had good parts from them anyways. http://www.rockauto.com/
  #29
Old 04-14-2012, 02:40 PM
Thanks a lot for the knowledge on the the ECT SENSOR. It's not stalling anymore. I have 1 new issue and 1 old issue. New issue: the coolant reservoir has a crack so now I'm losing coolant from the reservoir. Old issue: still will not crank and run the MAF sensor plugged. Any suggestions?
  #30
Old 04-14-2012, 03:50 PM
greenmachine96's Avatar
if it wont start with it plugged in i would replace it.
Katzen
07-04-2011 01:17 PM
noah3210
05-09-2010 09:36 PM
speakerfritz
12-04-2008 11:02 PM
TwistedEdge
10-02-2008 04:27 PM
Quick Reply: Need to get her running right before a road trip in a couple months....
