LT1/LT4 Tech 1993-1997
Need to get her running right before a road trip in a couple months....
Old 04-04-2012, 11:18 AM
334SRED96SS's Avatar
The oil is fine... The coolant I haven't checked since I bought it
Old 04-04-2012, 11:20 AM
Could the fuel filter be the problem?
Old 04-04-2012, 12:46 PM
One of the peers before me rigged a fan switch so u can manually turn the fan on and off for the radiator... So it could be the problem... It ran better but still stalled prior to me turning the fans on...
Old 04-04-2012, 08:10 PM
test the temp sensor on the front of the water pump. the list here gives what ohms it should read at that temp. 4th Gen LT1 F-body Tech Articles
Old 04-05-2012, 12:16 PM
Could also be that the IAC is not working properly and not controlling the idle speed.
Old 04-06-2012, 10:56 AM
I plan on taking my throttle body off and taking my IAC out and cleaning it..
Old 04-06-2012, 12:01 PM
So I removed the four bolts from the throttle body and it will not come off am I missing something?
Old 04-06-2012, 12:20 PM
Originally Posted by craby
check all fluids. is it low coolant or low oil? check coolant at the radiator,,, after its cooled. check oil level.
Checked all the fluids everything is good...
Old 04-06-2012, 12:22 PM
I can't get my throttle body off...
  #20
Old 04-06-2012, 02:27 PM
got all the linkage unhooked and all that. should come out if you got the four long bolts in the corners.
Quick Reply: Need to get her running right before a road trip in a couple months....
