LT1/LT4 Tech 1993-1997
My cam is unusually quiet
Old Jun 28, 2011 | 12:14 AM
Ucfz28's Avatar
Sorry for the slow replies on my part and thanks for everyones input so far, the compression is 11:1. I used cam break in lube on the cam when i installed it and even on the initial start up it had no real lope to it. I can make out the smallest of differences between it and the cc305 that was in it but I really expected a lot more from it. Im kind of at a loss here as to why it didnt turn out how i expected it too, murphys law I guess. Id love to be able to find the technical reason to it and fix what ever it is.
Old Jun 28, 2011 | 12:18 AM
Ucfz28's Avatar
Originally Posted by lt1 xjs
From what I've seen they do have a nice lope, should put around 420 to the wheels and run 11.5x-11.6x at the track with good heads, LE2 etc.
On a side note I have the Trick Flow Specialties TFS-30400010 - Trick Flow® GenX® 195 Cylinder Heads for GM LT1 - Overview - SummitRacing.com for the heads
Old Jun 28, 2011 | 10:04 AM
make a recording and let us hear it.
Old Jun 28, 2011 | 01:18 PM
Ucfz28's Avatar
That may prove a little difficult right now, Im out of town for the next three weeks
Old Jun 28, 2011 | 01:22 PM
Psycho's Avatar
If the cam was degreed incorrectly it will result in a performance loss and could make the lope less noticeable.
Old Jun 28, 2011 | 04:00 PM
Ucfz28's Avatar
degreed? as in grinded incorrectly? What would the chances of that being?
Old Jun 28, 2011 | 05:53 PM
greenmachine96's Avatar
no, lol, find top dead center and then check this out..... YouTube - ‪CRANKSHAFT CAMSHAFT TIMING DEGREE WHEEL INSTRUCTIONS ON DVD‬‏
If you didnt do this your valves maybe opening up at the wrong time. Which might cause what you are experiencing.
Old Jun 28, 2011 | 06:12 PM
Ucfz28's Avatar
Thanks for the video, I used the cam and crankshaft gears and lined them up the same way they were on my old cam. I dont see how anything would be wrong there since there is either the right tooth lined up or not and if it wasnt wouldnt the engine have problems running at all being that far off?
Old Jun 28, 2011 | 08:28 PM
Yeah it most likely would run extremely bad or not at all. Craby might be right about the stroke affecting it too.
Old Jun 28, 2011 | 10:27 PM
  #20
it should sound like mine does. i have a tad smaller cam with a similar setup.
