my air injection removal manifold plugs aka oil drain plugs! pics
so i removed my air pump when i replaced my opti and water pump. i was digging thru our box of oil drain plugs at work and found ones that thread right into the stock manifold. i was going to just weld the stock ones origianlly and i did but these look nicer
no clue what size they are or what they fit. there was a plug for a engine block or trans that fit too
You can buy NPT (National Pipe Thread) plugs in the plumbing section of your local hardware store. Without knowing the size, you'd need to take the old fitting in with you to match the diameter, or use a micrometer if you have one. How hard was it getting your air tubes off the manifold? That's the toughest part of the whole thing.
well you still need to know the thread pitch and all that good stuff. i vhave my micrometer out right now and one of those plugs its about 21.45 mmm outside the threads and 20.66 in the valleys. i used to have a thread gauge i think its a 22 x 1.5 plug though
remove maf and intake and theres about 3 bolt holding the air pump in and 2 hoses and a wire connector.you have to remove the coil and ignition control module but its really easy. the stainless tube is harder that goes from one side of the exhaust to the other. i just cut it in half under the crank and wiggled it out.theres no gains from doing this just ugly usless junk in a already crammed engine bay. and if you get non emissions headers you cant use it anyways. car will still pass emissions tail pipe test without it
