motor mount issues
the rectangle motor mount shell is not matching up to the block. the other motor mount fits on the k-member as well as the to brackets. its a 93 motor goin into a 95 car is their something diff about the years. if i can get a pic or if im doin something wrong i could def use the help thanks
blocks are the same so if your using a 95 mount it should work. i have a 96 motor in my 93. remember the bracket goes on the motor on one side and the frame on the other.
yea i remember that part. you wouldnt happen to have a picture of the triangle motor mount sitting on the block would you. ive been lookin for a picture but half of them i cant even make out what it is. thanks
