LT4 Cam
LT4 Cam
will this kit fit my 93Z?
http://store.summitracing.com/partde...p;autoview=sku
If it does, will it work with a 4.5 psi boost supercharger and safely with a 75 wetshot of nitrous?
RE: LT4 Cam
The biggest thing that you have to worry about when installing new cams with forced induction is the overlap. To much overlap and you going to start blowing alot of that forced air right into the exhaust line. Though i know this to be a turbo charger problem im not sure about a supercharger problem but you should check it out
RE: LT4 Cam
You have the same problem with any forced induction. A blower grind cam will work out better. Although, with a timed injection system, only air gets blown through, which isa not a bad thing as it helps to cool down and purge the cylinders, but still needs to be done in moderation. Until you get the Kompressor sorted out, I suggest not messing with the nitrous.
RE: LT4 Cam
The LT4 cam is one step up from sock, but the Hotcam is even more aggressive, compare the stats of the Hotcam from summit to the stock LT4 stats from here http://www.grandsportregistry.com/lt1vslt4.htm
