LT1/LT4 Tech 1993-1997
lt1 trouble
Old 07-01-2008, 02:52 AM
derekss123's Avatar
Default lt1 trouble
i have a 1995 z28 with the lt1. my car has a rough start if i dont give it gas then it dies and when i drive it the car overheats if i just idle. also when i first take off the car hesitates to go and it does it again around 40mph does anyone know what it could be someone said it could be a clogged cat.
Old 07-01-2008, 03:40 PM
Default RE: lt1 trouble
Check engine lite lit?
Old 07-01-2008, 08:05 PM
derekss123's Avatar
ya it comes on and off but when it comes on the ac shuts off and only hot air comes out. also i had a mechanic check my cats and there fine
Old 07-01-2008, 08:11 PM
derekss123's Avatar
he also said that i have an electrical problem. the computer wont put out any codes. hes the car surges when i first go and he has no idea what it is so i have to take it to and electrical mechanic. i dont overheat any more.
Old 07-01-2008, 09:46 PM
The reason the scanner gets no codes is probably because the wrong scaner was used. Yous car needs a ABDI scanner but the connector is for OBDII, so a bastardized connecting cable is needed. Get the car scanned by someone that really knows about your car and take care of whatever codes are pulled first.
jeanann73
02-02-2013 09:05 PM
smallzz28
12-08-2009 04:17 PM
Chevy101
02-11-2009 02:21 PM
94firstcarAcamaro
02-11-2008 09:58 PM
99 Camaro V6
01-06-2007 02:55 PM
Quick Reply: lt1 trouble
