LT1/LT4 Tech 1993-1997
LT1 Startup after sitting up
Old 09-10-2009 | 09:16 PM
BadVRod's Avatar
Default LT1 Startup after sitting up
I'm doing an LT1 swap into a 2nd gen f-body. Then engine/trans package I have has been sitting for a couple of years with no fluids in either the trans or engine. It has been kept dry and rather clean.
What steps should I take prior to starting the engine when the time comes? Should I go through disassembly and regasketing or fill with fluids and go? Any help greatly appreciated!
Old 09-10-2009 | 09:20 PM
cbr600rx7's Avatar
You will need to rebuild them before you try and run them. The rings in the engine are probaly rusted to the walls at this point and the valves are probaly rusted shut. You can not just leave a engine or tranmission sit for years with out any fluids in them. I would strongly recomend a rebuild.
Old 09-10-2009 | 10:19 PM
if its out of the car rebuild, oh wait build it. lol.
Old 09-11-2009 | 12:22 AM
rondavis's Avatar
im with craby build it
Old 09-11-2009 | 12:23 AM
rondavis's Avatar
plus you can deck the heads and run an 11 to 1 comression motor on 93 easy and still drive every day
TheArtfulLodger
04-07-2012 03:56 PM
CoyotesLaugh
11-29-2010 07:09 AM
JordanN
09-09-2010 06:08 PM
Rawr12345
82-92 V8 Tech
06-29-2008 08:41 PM
illumastar
12-29-2006 07:15 PM
