LT1/LT4 Tech 1993-1997
LT1 rebuild and HP estimate
Old Feb 25, 2012 | 10:23 AM
97SuperSport's Avatar
Default LT1 rebuild and HP estimate
Hello all,
I just had my 97 Camaro SS rebuilt with the following:
It was bored .30 over
ZZ4 cam
Roller rockers
And everything else was replaced of course.
It has the stock ignition, exhaust manifolds (Headers were to expensive to buy and install at the time, would it make a big enough difference to go ahead and do?).
It has the SLP cat back exhaust and ram air.
The shop said it would have 420-430 hp when done. Is the correct? I know the stock SS in 97 had 310.
Would the stock ignition system be good enough for this without holding it back to much?
Old Feb 25, 2012 | 10:38 AM
are the heads stock? with only what you have listed in your post the gain is not that much. can improve the ignition with a multi coil system and minimize the use of the opti.
Old Feb 25, 2012 | 12:02 PM
grabbem88's Avatar
That shop lied with basically a rebuilt engine and cam you will be lucky to see 340hp
Old Feb 25, 2012 | 12:58 PM
Even with it being bored .30 over and flat top pistons?
Old Feb 25, 2012 | 01:04 PM
+1
The GM ZZ4 cam is a High RPM cam. You might see 100hp at 6500 RPMs No way would a stock tune and stock exhaust manifold support much over 6000 RPMs. Your shop should know that. They are either clueless or lying. To get the full value of that Cam you would need header, Tune and atleast light port and polish on the heads and intake. There are a lot of better Cams out there for your LT1
Old Feb 25, 2012 | 04:55 PM
i guess it depends on what is ment by when your done. does that mean when your done with the exhaust and whatever else was mentioned? at the crank, its not that hard to get to 400.
Old Feb 25, 2012 | 05:43 PM
grabbem88's Avatar
True craby and atleast he has a fresh bottom end and whenever funds are suitable he can add heads,exhaust a better cam within valve clearance anytime he wants.
UserNamesSuuck
Nov 8, 2009 08:36 PM
vteckiller
Sep 25, 2009 08:38 PM
Unit94Z28
Sep 25, 2009 05:22 PM
camarorz28
Feb 3, 2007 05:49 PM
Don Hog
Oct 12, 2005 12:53 PM
