LT1 oil pressure
#22
10lbs per 1,000rpm = If you are revving up to 6,000rpm, a good pressure number reads 60psi.
Short of installing new cam bearings, sort of drop the crank, also remove rod caps = Install new, tighter fitting bearings. Even use different size bearing inserts on one side of the half cap(s) or "C" clamp(s). To shrink the diameter around the journals, you mis-match bearings, they still press "round" in a perfect circle as if both bearing inserts were even as well. < Old School.
#24
try a little heavier wt oil. 20w40 something like that.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
