LT1/LT4 Tech 1993-1997
LT1 Nightmare 3rd engine need help badly
Old Aug 1, 2013 | 01:48 PM
Cool
if you have a obd1 scanner you can do this. code reader will not work on 94 up.
Old Aug 10, 2013 | 12:26 PM
VALHAR's Avatar
1995 is a OBD 1.5 witch is a OBD 1.0 with a computer controlled transmission. The 1995 is the only year with a OBD 1.5 on a Camaro/Firebird. OBD 1.0 scanner won't work, unless someone can show a video that a OBD 1 scanner can scan a OBD 1.5.
http://en.wikipedia.org/wiki/On-board_diagnostics
Old Aug 10, 2013 | 12:50 PM
94-95 are OBD1 95 is called OBD1.5 because it has a OBD2 connector. The above picture tells you how to use a OBD1 scanner with a 95. FYI the only 4th gen without a computer controlled trans is the 93. 94 has a PCU not a ECU like the 93 has.
Somewhere there is a thread that explains the whole 94-95 nightmare and all the scanners that are plug and play.
CheVy_R0aRrR
May 23, 2011 07:50 PM
camaro4life
Apr 2, 2008 08:14 PM
The_Shadow
Nov 2, 2005 11:33 PM
