LT1/LT4 Tech 1993-1997
LT1 Mass air flow problems
Old Aug 18, 2013 | 09:06 PM
htownZ's Avatar
Default LT1 Mass air flow problems
Greetings, I've got a 94 Z28 M6 that I rebuilt the engine back in March. It's got a Lunati cam and 1:6 rockers, ported and polished heads, headers, blah blah blah..I'm working with Soloman on the computer tune and when I sent him the first data log I was informed that the engine is running lean at WOT and that the MAF numbers are way too low. I've cleaned the crap out of the MAF that is only 3-4 months old and the numbers are still too low. The voltages to the sensor are correct, so I'm wondering if the brand new sensor is bad, or is there any other things that could cause the sensor to put out low numbers? Thanks for any advice!
Old Aug 18, 2013 | 10:35 PM
yep could be a bad new part.
Old Aug 21, 2013 | 12:26 AM
Also check for air leaks between the MAF and throttle body.
sergio805
May 31, 2010 08:24 PM
lt4weeda
Apr 24, 2009 10:26 PM
jml317
82-92 V8 Tech
Dec 12, 2007 02:44 PM
97rsturbocamaro
Nov 18, 2007 09:57 AM
