LT1/LT4 Tech 1993-1997
lt1/lt4 heads
Old Nov 4, 2010 | 05:26 PM
bigdaddykearns's Avatar
Default lt1/lt4 heads
ok new to this forum . i am buildin a lt1 camaro for my bro i want to do the lt4 cam and heads so my question is if i buy the head kit and it myself will i have to get the heads ported so the vales will fit?
Old Nov 4, 2010 | 05:37 PM
Buffalo02Z28's Avatar
I believe that it should bolt up to the LT1 and work fine with no problems. Are you buying the heads and cam in a package? They are usually sold in a package together.
Old Nov 4, 2010 | 06:48 PM
You will also need a LT4 intake. For the same money you could get much better flowing heads, and a matching cam.
Old Nov 4, 2010 | 06:51 PM
i was going to get a lt4 hot cam kit and was wondering if the valves will fit in the stock heads or would i need to port them or buy diff heads. and yes i have found the cam kits with springs rockers cam but no valves.
Old Nov 4, 2010 | 06:54 PM
i laready have the bigger throttle body and intake and bigger injectors just trying to find the cheapest easiest way to do the hot cam kit and heads
Old Nov 4, 2010 | 06:56 PM
Thats right, I forgot. You will need the LT4 intake to include into the package. This whole package is rather expensive and most choose not to go with the LT4 package because of this.
Old Nov 5, 2010 | 05:37 PM
ok then ur opinion what would be the best thing to then that doesnt cast so much ?
Old Nov 5, 2010 | 11:36 PM
ricer_killaZ28's Avatar
well I'm not sure how much that whole set up costs but alot of guys around here recommend Lloyd Elliot, I believe the website is elliotsportsworks.com or elliotsportworks.com, just google Lloyd Elliot and check the site out
Old Nov 5, 2010 | 11:45 PM
I would go with Trick Flow cylinder heads, stick with the LT4 Hot cam and get the intake ported.
Old Nov 6, 2010 | 02:03 AM
lt4 cam is not that hot.
